painted my grille black
Many of us DIY it. We sand away the chrome, spray it with rattle can paint by Kylon Fusion plastic paint and then clear coat it.
No need to completely remove the chrome. I use the 3M brown Scotch-brite abrasive pad to scuff the chrome. I use the Eastwood 2K Clear. The Eastwood clear is 2 parts with a harderner and clear in one rattle can. You activates (mix it) when you ready to use. It only has a shelf life of up to 48 hours. Any left in the can will harden cannot be used.
yes i did all of this at home in my garage. I scuffed it down with some sandpaper then I used 3 light coats plastic based primer which just primer that is for plastic surfaces. after it dried i wetsanded with 2500 grit to make it smooth and let it dry. I sprayed 4 coats of rustoleum gloss black high performance enamel and then 4 even coats of krylon clear. I plan to wetsand the pieces i painted and buff them out after the paint cures because in some areas it did get not shiny and there was slight orange peel. and i did the same with my grille. also i cant stress enough to do this on a not windy warm sunny day! It makes things a lot easier.
Good job everything came out nice. I just used rattle cans to paint my wheels and the next project is a DIY full chrome delete. Did you take your handles off to paint them? I didn't remove my tires when I painted my wheels it just took a lot of patience applying painters tape to mask everything off.
does this help? i heard it was a pain in the ass to take em off so i masked them instead. with the big gaps its not hard at all
Nice masking job. Hope you were able to do really good job prep/clean the pieces to be painted so the paint stay for the long run. They came out nice.
turned out Great, looks good. whats the next mod?
wheels and suspension. I ordered 22" forgesters
---------- Post added at 06:26 PM ---------- Previous post was at 06:24 PM ----------
Yea i used alcohol after I sanded easy to mask with those big gaps
Looks like you were extremely thorough with the paint preparations. Looking forward to seeing the finished product! I'm sure it turned out great!
yea after i get back from wekfest tommorow ill wash it and give the trim some compound
a4179a16769e413f3c23a8b27bc912ac.jpgd0a523639b4ad6cb95e932de654aad9e.jpg5dfac37fe7e62ba084e434f789da317b.jpg4cdb75303a434011ede81e81700a896e.jpg
the detailing never happened after wekfest but i just got the car washed and finished off the handles. i think I want to debadge the car. both the "fx35" and the infiniti logo. lemme know what yall think.
I would debadge it but def keep the Infiniti logo. I would also black out the window trim as well.
yea bro. i tried this shadowline vinyl bs and it didnt work it just started bubbling up. i will paint them later on. i really want to remove both of them because it looks cleans as hell.41eb84406a49acb4d72060873042f738.jpg trying to get him on the forum
I follow that guy on Instagram, he has a sick fx
