Mako3
- Vancouver, WA
- 2006 FX35 AWD
Hey all!!
So 8 months back I had an overheating issue with my 2006 FX35, noticed the lower radiator hose was cold, ok thermostat repair. Bought replaced, burped the system, and the problem went away for a month. It came back, I bought a new radiator cap and flushed my whole coolant system. Fixed it for a week and overheating came back. So I decided to just take it to Beaverton Infiniti, they ran some diagnostics and said in the pressure test they found out my radiator was bad. Ok, I myself installed a new radiator and replaced the upper and lower hoses while I was at it. A month later it started overheating again, I burped the system and it was good for about another month, I burped it again, and this continued all the way up until now.
My lower radiator hose is still cold to touch. I replaced the Tstat again and that didn't fix it. I just did another coolant flush today and idk where all the coolant/water is going but its disappearing about as fast as I can fill it. When I was filling her up she was bubbling water badly everywhere, I couldn't catch a break. Also I had the heater maxed on 90 with fan speed low at first to high, makes no difference. It's blowing ice cold air out and car is overheating. Today while diagnosing it and trying to burp her, I briefly got hot air to come out the vents but along with it came vapor. It quickly dissipated in seconds, but found that odd. Idk what to think, I'm calling Infiniti later today to discuss their terrible diagnoses. I'm afraid the compression test they did means I have blown head gasket and not the radiator they thought, since that's been replaced and issue is still occurs. Or perhaps it's a bad heater core? Any thoughts on This? Or is there a trust worthy head gasket sealer / stop leak? I was honestly tempted to try "Bars Leaks Head Gasket Fix or "BlueDevl"
