low88111
- San Francisco
- 2004 FX45
i was wondering how many miles until you 45'ers original radiator gave up or ended up cracking due to the plastic wearing
okay, so im hoping to still have a good amount of life left in my original
also MTN FX, i havnt looked into it yet, but why did you need ATF for a radiator replacement?
Not sure about th 45 but the 35 has a trans cooler line into the radiator. Since I had to open the line there was some fluid loss so
I let it drain overnight then added that amount back to trans when done with work - killed two birds with one stone , trans fluid serviced too :smile (2):
The trans fluid also run into a separate tank in the radiator on the FX45 for cooling just like the FX35. Topping off the ATF is needed.
