offset result ...20" x 10" ,/ ET 32mm
sirtrojan
Poland, Warsaw
2006 FX35 AWD
This is result for 20" x 10" wheels . Is it enough to run without any spacer?
thanks for comment.
Extended 47mm puts you flush in the rear (not sure about front). How do I know, GT-R rear wheels are 10.5 with a 25mm offset and they sit flush according to others on here, they require a fender trim to fit though.
I am extended out 29mm currently and I am not flush. Would need to go another 10-15mm or so I think which would put my 10.5" wide wheels at an offset of 33mm - 28mm.
You're very close though and maybe 305 tires would buldge a little giving you flush.
