champaign777
- Chicago IL
- Infiniti QX70 Sport
Front Struts , Sway Bar Links and Sway Bar Bushings:
So long story short, when I bought my infiniti JX35 35k 5 years ago I had doubts about front struts and I was right . Something was wrong with them ( this low sound aka bum boom boom going over bumps and some additional clunking noises ) . This was not critical at all on a highway so I stayed with them for another 80k miles hah ... With all today's situation and being a Smart Ape who hates monthly payments I decided to keep this car . It is good , really good with all Tech , all possible options including Theater it's just not in my book to replace it for something similar +$50k on the top of my head LOL but front suspension needs some tunes so i replaced front sway bar links and all is left to replace the struts and upper struts mounts + sway bar bushings
I decided to go with new OEM FULL STRUTS/SPRINGS Assembly and here are my results .
I was doing some intensive researches and end up with
<<< Suspension Strut and Coil Spring Assembly >>>
which are HARD to find so i am sharing with you guys the OEM part numbers
E6C00-9NFOKNW
E6C01-9NFOKNW
Most dealers are selling parts but replace Assembly with 5 bolts/connections total is one thing and replace failing strut parts is like 5x more job LOL just to suppress the springs can wipe out most of fox here haha
Just FYI :
Just a LABOR cost of struts / shocks , sway bar links / bushings replacement all around ( parts are NOT included ) will be around $2000-2500
Parts itself ( OEM ) are around $700-800
Worse the try !!!
E6C00-9NFOKNW
E6C01-9NFOKNW
Just FYI :
Worse the try !!!
