When ever I go over a little bump I get this noise. Sounds almost likea click coming from the rear. Could this be time to replace my control arms? Any ideas? Its 2005 fx 35 awd as well if that helps
Dry Axles (rear)
Was a Common problem, & I'm pretty sure on remedy.
I think there might be a TSB for it. remove axles and lube with some grease. Tick Tick all gone
---------- Post added at 11:51 AM ---------- Previous post was at 11:49 AM ----------
hmm over a bump, you have an awd hence rear sway bar. Id start there get under the car and wiggle the endlinks see if you get the same sound. Next check out your exhaust pipes, wiggle it around, might have a broken exhaust bolt or something busted
