Nnamdi's QX70s
Like the door pull led you had. Would you mind share where you got them?
Yeah man of course! I got the LED bulbs on Amazon. Link: WLJH 6pcs T5 Wedge Instrument Panel 74 2721 3030SMD Canbus Error Free LED Instrument Speedo Gauge Cluster Light Bulb,Blue https://a.co/d/87gK90X
I also got the connectors I used on Amazon as well. Link: Modengzhe 10 Pcs T5 Twist Socket Car Dashboard Wiring Harness, Panel Cluster Plug LED Bulb Wedge Light Base Cable for Automobiles https://a.co/d/bG5IQBo
Thanks :tup:
Finally got around to getting the front Aero installed. Such a HUGE difference. Very happy with it! Install was easy and straightforward, took me under an hour taking my time.
View attachment 607522 View attachment 607529 View attachment 607517 View attachment 607519
View attachment 607518 View attachment 607525
Tucked away :)
View attachment 607526 View attachment 607528
That front lip looks really good! Do you have a link or any tips on how I can find one for my 2017 QX70? I think my color code is K23- Light Silver. I’ve been looking around but i haven’t found anything I'm confident is the right part.
Sorry I am just now seeing this! I would just check online with dealers from different states. I ordered mine from Infiniti of Austin - and if you sign up for their membership program you get a pretty decent discount on your first order. These aero kits have definitely gone up a lot in price recently so I'm glad I got one when I did. So I would just check online. A lot of the time it will say that it wont fit your year and model car, but just keep in mind that pretty much everything for these cars (especially the aero parts) are going to be the exact same from 2009 and up.
View attachment 607383 View attachment 607387
While I was "in there," I swapped the upper rear coil spring isolators for thinner ones. Forgot to take measurements beforehand, but if I had to guess I got another ~0.5" of drop in the rear. Drives just as it did before, no new NVH. Happy w/ the results!
Factory isolator
New thinner isolator
View attachment 607388 View attachment 607389
View attachment 607390 View attachment 607391
How she sits as of now!
Are you able to share where you got the thinner insulators from?
