NISSAN OE Caps are rated at 0.9kg/cm (12.6lbs) and 1.2kg/cm (16.8lbs) for turbo vehicles.
Holds higher pressure than stock cap for added cooling capacity.
30,000 is the mileage interval recommendation to replace the radiator cap, so if you have to change it anyway, might be a good time to upgrade. I don't think many really follow this recommendation, I don't... I test my cooling system and no issues.
