- Los Angeles, CA
- 05 FX35 RWD
yes, I was dyno-tuned.GTO - Did you go to technosquare to have it tuned on a dyno or did you just give them your ecu?
For the most part, Tadashi has most of our general mods input'd, so he can just plug in the adjusted map. But that's if you just send it in.
On the dyno, which is obviously better, he has his laptop plugged into the comm slot under steering wheel, & adjusts after each dyno run. That way he can take you to the upper end of safe limits, & concurrently set your air/fuel. He made several adjustments throughout my 5 runs. This is always the better way if possible. You'll still get a decent tune through the mail, but not at its upmost potential. It'll be a tad on the conservative side to keep your gear safe.
