New to the FX and having issues already.
I took the alternator off and took it to a rebuild shop that I use for my race car and they said it was fine. I have replaced both cam position sensors, crank position sensor, checked battery and altenator. But still having the issues. Seems like it is getting worse. Car sounds like the timing is Wayyyyyyyy off!! I'm hoping the sensors haven't been screwed so long that it's screwed the ecu.
What I would do is pull the negative wire and press the brake couple times to do the ECU reset for the slip and VDC. If still there, then like the others said for the camshafts.
Sent from my SM-N915T
