3.5L New noise coming from engine bay
Discussion in 'QX70 Engine & Drivetrain' started by themadnewfie, Feb 12, 2018.
Tags:
  1. themadnewfie
    themadnewfie Member
    55
    3
    Windsor ON Canada
    2009 FX35
    Brian
    Hi!
    So it's been cold and crappy as far as Canadian winters go - but with 4 new winter tires and heated seats I should be good .. Right?
    Not so much - please have a listen to the below link .. I have a rattle type noise which is much louder on the passenger side of the house and I'm curious if anyone has experienced the same and might help me identify which part is failing (no other noticeable changes to speak of - if heater is on or off still no difference)
    Please help
  2. 6T9CHGR
    6T9CHGR Member
    175
    28
    SINY
    2012 FX35 LE
    Chris
    Definitely sounds like a bearing failing in one of your accessories (alternator, AC Compressor, idler pullyes etc) Take belt off to isolate which one it is. Spinning each one by hand should tell the tale (grinding, not smooth spinning)
    NashFX likes this.
