New INVIDIA FX35 FX45 exhaust dual canister NO RASP. PROTOTYPE AVAILABLE SOON
Invidia may provide gaskets for all the connections but the two at the cats though. I thought someone said this earlier. Since it's a true dual, you have more connection points, and therefore more gaskets, that's why you counted 12. Mine uses 7, but it's not as complex as the Invidia.
There is 6 gaskit inside Our Gemini Exhaust Muffler to Mid-pipe use 2 Mid-pipe to X-pipe use 2 X-pipe to Flex pipe use 2 the Flex-pipe to HFC's use a Stock OEM gaskit When you purchase HFC's or Test-pipe u will receive New pair gaskit for the flex-pipe to Hfc's or test pipe...
You don't need buy additional gaskets except those ones between the y-pipe and the cats. I recommended buying those gaskets because to avoid any possible leakage between the y-pipe and the cats.
The Invidia Gemini has come with all other gaskets you needed except for those ones.
Got my exhaust today by UPS this morning. Opened the box and everthing checked out good. I installed it right after work. I will say more tom. Im tired as hell. I will post pics of the install and other info.
I'll bet 100 dollars and a dog turd that if it was problem you have noticed it by now :wink: OR maybe your ears are so plugged with 370z love you can't hear the leak?:smile:
Here are some pics of the exhaust/install. This exhaust is worth every penny.
Just arrivedView attachment 176950
FX up on all 4 ramps
Parts that came with the exhaust
Old exhaust out. Came out real easy.
Cats with nothing attached yet. View attachment 176963
Rear section empty.
Damage to the exhaust from shipping. Fixed it with a pipe and hammer. Placed the pipe on the inside and banged out the dent.
New gasket from the cat back. (Not included from invidia) they should include it but they don't. It is what it is. Picked up two new gaskets from autozone. Felpro. **I had to trim the gasket down a little because it was smaller the the invidia pipeing. I didn't the gasket blocking any airflow.
Finished!
As for the tips, the designed for the clamps are pretty weak. Im going to a muffler shop to have them welded on. The clamps don't hold it to tight. I feel as though through much vibration they may come off. Other then then that this exhaust is nice. Youtube videos really don't do it justice for the sound.. Once your in the FX and driving with the windows open, it sounds gooooooood. It's like the factory tone but more throatier. It's not tooo loud and neither tooo low. You feal a difference right away. Thanks again gordon.
should i get the tips welded when i get this installed? cause they are already welding things on the exhaust and it would be easy for them. Are the clamps really that bad?
