Cakeboss107 Member Location Boston Massachusetts Car 04 FX35 AWD Name carlos Jan 16, 2016 #1 Need help wat is the fix for po605
jbaker1121 Im in touch with humanity iS VIP Location Westchester, New York Car 09 FX50 Jan 17, 2016 #2 p0605 is the ECM throwing a code. Engine Control Module (ECM) may be faulty - ECM harness power supply circuit is open or shorted - ECM harness ground circuit is open or shorted Try resetting the code with the code reader. If that foesnt work you will probably just need to buy a new one and replace it. if you are more handy, you can try testing the power to and from the ECM and stuff like that...
Cakeboss107 Member Location Boston Massachusetts Car 04 FX35 AWD Name carlos Jan 17, 2016 #3 Ok so if i buy a new ecu is it plug & play or is there something else that needs to be done ---------- Post added at 03:31 PM ---------- Previous post was at 03:31 PM ---------- Where is the ecu ground located?
jbaker1121 Im in touch with humanity iS VIP Location Westchester, New York Car 09 FX50 Jan 17, 2016 #4 i think if you find one with the same options on it then it should be plug and play. not sure about the ground
