Anyone have install the 4 Point Ladder brace themselves? I would love to hear how you install it. So far, I have install all the braces myself. I'm having a little diffculty with installing this one. The problem is the location of the two front mounting points. The brace is designed to mount to the existing bolts that mounts the lower control arm to the crossmember. The problem is right behind the nuts is the steering linkage and boot. I can fit a 19mm or a 3/4 inch socket with a break bar. I drive the car on ramps still not enough ground clearance to crank the break bar. I tried with an impact gun with a universal joint to bend away from the steering linkage, but afraid to try it as it is such a tight fit and it rub against the steering linkage boot.
Sorry, I forgot to take picture of the install point. I'm sure those that have install this brace themselves know what I'm talking about.
