My Review of Superbrightleds.com
Status
Not open for further replies.
mrpanther
Arcadia, Temple City, Walnut, Eastvale, CA
2019 QX60 PURE FWD
Will
So I decided to swap all my interior lights to LEDs and went with Superbrightleds.com.
I ordered:
10x 3022-x9 LED festoon bulb - WHITE
4x WLED-x6 LED bulb - COOL WHITE
6x 3022-x4 LED Festoon bulb - COOL WHITE
here are the results:
used 2x WLED-x6 LED bulb - COOL WHITE
results: looks great, exactly the way I pictured it
Cargo light
2x 3022-x9 LED festoon bulb - WHITE
Results: not as bright as i thought a 9led bulb should be, but satisfactory
Rear Passenger seats:
3x 3022-x9 LED festoon bulb - WHITE
Results: Same style bulbs, but color variation between the bulb was large! the Right rear passenger light almost looked like a pale yellow.
Front driver/passenger lights
Results: same as other ones
2x 3022-x4 LED Festoon bulb - COOL WHITE
Right side Step lights
Results: no where near cool white. One's completely blue.
Left Side Step Lights
Results: Same as right side. blue
Total install time: 50~ mins (took forever to find a screwdriver to fit the smaller interior light screws
2 9led bulb only has 6 working leds
2 9led bulbs are not led white. more pale yellowish
3 4led festoons are light-med neon blue.
notes:
- the step lights are listed as 3022, however the bulb is narrower than regular interior lights.
- The Festoons are a bit wider than our normal yellow festoons, so It doesnt snap completely into place. (may be why some ppls leds burn out so quickly, or flicker)
those look great.
As for my experience with LED bulbs on the FX. I installed Yellow LED turn signal w/ ballast and I really don't think they are bright enough (def less bright than stocks) I put the stock ambers filament bulbs in the DTRL (so Bright).
I did the license LEDs also like you, but I picked ones that were not as bright on purpose, but still white.
Mod on.:wink:
I I have LEDs in my license plate area and they look good.
I used to have them in the reverse lights but took them out cuz I couldnt see a darn thing when in reverse.
i thought all my interiors werent as bright as original when i first swapped them and i was a lil mad cuz they arent cheap... but once my eyes got used to the white instead of yellow i was very happy (and both roommates ended up getting them too ) i believe mine are 12leds(all the interior)... i was also really mad that over 1/2 didnt work until i discovered theres a wrong and right way (pos/neg?) to put them in
i have autolumination LEDS on my license plate and my reverse lights. the plate lights are slightly boue but arent that brgith, and one of them keeps going oiut...which i guess is good for me bad for cop's cameras:)
but they look good
im trying to get a hold of the amber lights that are chrome when they arent lit....anyone know of any good ones wher ei wont need to theing so it doesnt blink fast?
I must've gone through like 10 superbright leds before switching to PIAA led bulbs. leds from superbright do not last long. They typically last 1-3 months before dying or hyper-blinking. That's from my experience.
I've had mine since Rookie had his GB from the Org last year, I dont think I've replaced any of them yet.
quote]
your plates have a reflective coating, so the lights being out doesn't matter. They will still see it because of the reflection.:eek:
Status
