I've gone through most of the threads linked to the Motordyne Spacer, but I haven't really seen much on the results. What are users experiencing? Was it worth it? Any long-term feedback, good or bad?:wub:
Thanks for the feedback. I think I will go with the 5/16" vs the half inch because of compatibility. I live in the Northwest. From Motordyne's website, it looks like the copper ISO thermo (on sale $274) might be the way to go for me. They state it's a plug and play version. I wouldn't have to mess with a setting. Here in the NW, the temperatures fluctuate rapidly. What do you think? By the way, after this mod, I will get the catback exhuast.
Also, im most cases, you have to reset the ECU.
Some members have the stock diameter pulley , but I will install the underdrive one.
here is more info
///275&highlight=pulley
http://www.unorthodoxracing.com/
Do the Motordyne spacer first:top:. worry about other mods later :2smile:
I will do the Motordyne first. Any experience with the Copper Iso Therm version out there?
for the spacers do u guys retighten the spacers every 5-6 months?
recheck torque specs with a torque wrench but do not tighten unless needed, these bolts break easily. If you do not have a leak or vacuum problems you probably are fine.
From Motordynes website, they say the 5/16" requires no modifications of the car, whereas, the 1/2" does. I don't want to do any cutting or outward modifications. So thanks for the offer, but I'll probably go with the 5/16". Also, I think I read the 5/16 is better for low end, correct me if I'm mis-informed.
