- Vancouver BC for now
So how come they are selling them at the Infiniti dealers and not the Nissan dealers?
cuz Metro is awesome
yea, I bought the extended warranty. But I have the plenum spacer and change the pipes from headers down, so but wanna get "blame" before they look at my engine................
yes, the white smoke coming out to the rear exhaust and the smell is burning engine oil. About the problem, we are not 100% sure if it is really the valve cover, but there's engine oil around the spark plug hole area and u can see the oil all over the 3 to 4 spark plugs, so should be leak from top to bottom which should be the vavle cover area. When we clean the oil on each valve cover and the spark plug holes, the smoke did significantly become less for a few days.
about 2 months ago, I went to my mechanic to install downpipes and change new spark plugs. We found that there's enigne oil all around the sprak plugs area and the leak is most likely from the valve cover and gasket. Since I installed the downpipes, tons of white smoke were coming out of the exhaust from the buring enigine oil. So I went to Cheryl and talked to her about the problem, they did find out the leakage from the valve cover and gasket and repleaced new one. To be more cautious, they decided to do an engine oil consumption test every 1000 miles to see if the eninge is also causing the smoke. The first test they found out my car burn off 1 quart of oil and so I have to come back for a second one. Today was the second test, they found out more eninge oil were brun off and decided to give me a new engine.
