So is it +30 w/ the 25mm spacer? Or is it +30 and then 25mm spacer so +5? I'm guessing the former since I can't see how a +5 on a 10.5 would tuck w/o extreme camber. Looking at your pic, you definitely will have issues w/ the part beneath the door edge if you go too aggressive. It's the part right at the corner of the door, I'm guessing it's a weld or something for reinforement. That part will not roll flat and I don't think cutting it off would be a good idea. Having said that, if you were to trim the plastic back and roll the fenders flat, you'd get a lot more space to work. I'll try to get a pic of my fenders.
BTW, if you want to go more aggressive in the front, you can pinch the fenders flat. That would give you a little more room to work with, but it won't make as big of a difference as rolling the rears. I'm going to do that soon, I already rubbed off one of the front wheel liner fasteners.
