Freddie's M45
I took a good look at the M45 y-pipe and I have to tell you it's as bad as the mid-pipe. It's choking the rest of the exhaust. I'm now looking for a shop to just change the piping on the y-pipe for me.
To get or release maximum power a custom y-pipe and a set of test-pipes would be best as so many like 350z, 370z, G35 & G37 owners have been doing for some time now.
But after talking to a fabricator in order to keep the rasp & smell to a minimum and not have to deal with dash lights (cel lights) it's best for me to keep my oem cats.
I would have to cut at the rear of both oem cats / add 2.5" pipe to the end of the oem cats all the way to the Megan Racing mid-pipe.
In other words replace the oem y-piping with 2.5" piping while keeping the oem cat's & sensor's in there same location as mounted from the factory.
This my not give me full power like running test pipes but replacing just the y-piping will help alot and will avoid having the rest of the problems (dash light, really bad smell & loud rasp sound). It will allow me to have 2.5" from the rear of the oem cat's to tail-pipe. It will make my M45 run & sound better and I should be able to pass NJ emission testing.
For those that already replaced the oem exhaust system with an aftermarket system please take a minute and look at your y-pipe it's hard to believe that it has section that are less than 2"
WHAT WAS NISSAN THINKING????
