M45 Flat Tire Reset
skyking
va
Hi everyone, this is my first post. Have a question:
I have a 2004 M45 that just had a flat, replaced, but have no tire pressure info. Book says to have dealer reset system. Is there any way that I can reset the system?
Thanks
resetting the ECu sometimes gets rid of it......
found here
Ecu reset, Acc. pedeal release pos., Throttle closed pos., Idle air volume learn - InfinitiScene.com
If you had a TPM sensor replaced or it is damaged then you will have to have the dealer reset them. This is not something you can do yourself.
I had my tires replaced before and never had to reset the Tpms . It maybe possible they damaged the sensor or maybe the TPMS needs a new battery?
+1 changing a tire shouldn't require you to reset the sensor. I've had all 4 of my tires replaced and the sensors picked up the PSIs right when I rolled out of the shop.
