The benefits would be great. But the down side of having something break is not worth it in my opinion..
Just curious and this is probably too easy but is there not a way to replace the flanges on the nismo or other vlsd's with the 45 lsd flanges?
Also, the 45 has a 3.7 final drive as the faq's state but a 3.5 would be better, correct? Would I need to replace both the front and rear diff's? or just the rear? More i read the more questions i have.
Ten years later, I'm trying to do this on my FX37.
Same song, second verse. August 2017.
I’ll be interested to see what you come up with.I'm not sure if you've successfully swapped to a VLSD or not. But, my RWD 10' FX35 (same for all RWD 2nd gen models) has the bigger axle stub flanges like the first gen FX45 models. Not sure about the AWD 2nd gen cars BUT The first gen RWD 35s are lucky because they have the same size axle stub flanges as G/Z models so almost a plug and play setup if you get a G/Z VLSD pumpkin. I'm currently trying to find a solution to keeping the smaller flange axle stubs that are on the G37 VLSD pumpkin that I bought and mating them to the Factory 2nd gen RWD axles. The harder I make it for myself, the easier you FXers will have it.
Meanwhile I have a much greater appreciation for the Set up, and actually respect the way it works in a clockwork orange sort of way.
That said, when I get around to it I might just search out an AWD rear differential since that’d buy me 10% steeper gearing, and still drive like Clockwork.![]()
