- Westminster OC
- car
Infiniti FX Lowering Springs
Lowering springs on the market that are compatible. Do not worry about AWD/RWD specs from some websites, the springs are compatible no matter the drivetrain type or engine type.
H&R Part number 53043 Front drop 1.3" Rear drop 1.2"
Eibach part number 6366.540 Front drop 1.2" Rear drop 1.2"
Intrax part number 60.1.075 Front drop 1.8" Rear drop 1.8"
Stillen H&R link http://www.stillen.com/product.asp?id=HRSPRT01&c=SU
Stillen Eibach link http://www.stillen.com/product.asp?id=EIBPROKT01&c=SU
Everything Infiniti H&R link http://www.trademotion.com/partloca...rtInfo&PartID=437226&siteid=55&catalogid=3323
Everything Infiniti Eibach link http://www.trademotion.com/partloca...rtInfo&PartID=437146&siteid=55&catalogid=3323
TireRack H&R link http://www.tirerack.com/suspension/...2005&autoModClar=AWD&partNum=53043&perfCode=S
TireRack Eibach link http://www.tirerack.com/suspension/...5&autoModClar=AWD&partNum=6366.140&perfCode=S
I have only seen the Intrax once on an ebay auction, have never actively searched for it. There are more Eibach owners than H&R owners, I have tried both and feel the H&R is a better spring for the average driver. I can see how the slightly stiffer ride from the Eibachs can compliment a sport minded driver but the H&Rs perform great as well.
We've had issues in the past with the correct part number for the H&R set up. The Nissan Murano shares a close suspension configuration and some have been sent the wrong springs in the past. Murano part number is 53047, if your box has this number do not install.
For someone concerned with ride quality I recommend the H&R's over the Eibachs.
