QX70 09+ Loose Driver Seat?
Discussion in 'QX70 Interior' started by wyatth, Feb 4, 2018.
  1. wyatth
    wyatth Member
    149
    30
    San Francisco
    Car:
    2015 QX70S
    It feels like when I take off or come to a sudden stop, there's a little play (fore/aft) in the drivers seat of my '15. I told the dealer about it last time the car went in for service, and they said the mounting bolts are tight. Well, it's still noticeable (to me, but not my wife). Anybody else experience this?
    I did search around and it's not unusual on other Infiniti models, but I am not sure what the cause is. Some people had entire seat frames/rails/motors replaced (which fixed it), but that seems excessive. I'd like some ammo to share with my dealer so that they take me seriously when I bring it up again.
    JonFull2015QX70 likes this.
  2. Adamg
    Adamg Member
    7
    2
    NJ
    Car:
    2015 QX70S
    Name:
    Adam
    Yes, same here on my 15. Interested to see what the outcome is. Waiting to make appt at Infiniti so I also dont get the run around.
  3. Infiniti2011FX35
    Infiniti2011FX35 Member
    14
    2
    Toronto
    Car:
    2011 FX35
    Name:
    Omar
    same thing in my 2011
  4. RIPnFX
    RIPnFX iS VIP iS VIP
    11,236
    691
    Los Angeles/Bakersfield
    Car:
    Infiniti FX 35 Limited Edition
    Name:
    Rip Singh
    Had this issue a month back, took it to the dealer and they replaced the seat railing under warranty which fixed the problem
    skywalker999 likes this.
  5. 6T9CHGR
    6T9CHGR Member
    187
    32
    SINY
    Car:
    2012 FX35 LE
    Name:
    Chris
    Mine seat track was replaced under warranty also in 2015 when I got my FX
  6. DatMan
    DatMan Member
    654
    121
    Ottawa, ON
    Car:
    2007 FX35 AWD
    Name:
    Dat
    Was a common problem in the 1st Gen and usually was the seat railing that was the culprit... Looks like 2nd Gen has similar issues...
  7. jumbosrule
    jumbosrule Premium Member Premium
    2,850
    77
    Redondo Beach, CA
    Car:
    2003 FX35T
    Name:
    Brad
    Specific to the first gen:
    It was actually a small plastic gear that sits in the seat railing - the "teeth" of the gear wear down over time and then it slips in the track. This is not a replaceable part, so the dealer just removes and replaces the entire track assembly.
    DatMan likes this.
  8. DatMan
    DatMan Member
    654
    121
    Ottawa, ON
    Car:
    2007 FX35 AWD
    Name:
    Dat
    That was for when the seat stopped moving... The squeaking seat issue was also mostly cause of the rails...
    But now there's somewhere where you can order just that plastic gear, so anyone of out warranty isn't also SOL :p
  9. DONZ
    DONZ Member
    14
    10
    Australia
    Car:
    QX70
    Name:
    Don
    i felt that today too....2014 qx70 diesel! i have till next april for factory warranty to go bye bye...ill see what happens!
    DatMan likes this.
  10. JonFull2015QX70
    JonFull2015QX70 Member
    13
    Atlanta
    Car:
    2015 QX70 RWD
    Name:
    Jon
    wyatth - I'm surprised INFINITI hasn't addressed this continuing issue; had same issue in my 1st-gen '05 FX35. Replaced in Oct 2013 (no warranty!). Driver's seat-track broke again in Aug 2017 (I weigh only 180). Frustrated with this known FX/QX defect, I complained to INFINITI Corporate re: new part shy of three years old and broke! Corporate relented and covered the cost of the track, while I agreed to cover $176 labor to install (or you could install yourself if so inclined). But, you should be covered under warranty - push your dealer a little harder. Often, the service tech would say they couldn't tell anything. The way I got them to notice was to sit in the seat like normal, grab steering wheel and rock back and forth in the seat; this usually demonstrates the issue clearly. Good luck!
