Lift gate panel removal?
jungy4
FX35
Has anyone removed the lift gate panel? I need to see if I can have access to the license screw anchor that keeps spinning.
Yea. Push in and remove all the body panel pins. ( There are probably a couple larger "pull" type) pry out the light and the lift button disconnect the pig tails. Then find a place to pull and it'll come off
You push in the center portion of the panel pins? No screws at all? Thanks.
Yes the ones with the small center push in until you hear a click. The larger ones need you to pull out until a click. Then the oins should be able to slide out pretty easy. No screws.
