So had Safelite change a windshield last year. Literally 365 days ago from today. About a week ago, the car would start, but no dash lights. Odd. I checked fuses, found the 10Amp "Elec Parts" to have a 15 Amp blown fuse in it... Its the one on the left side by the drivers foot, Fifth one from the top. I replaced with a 10Amp. Worked for a day. Next start, Dash came on for a second, then went off. Which told me fuse was blown again. Checked fuse, yeap blown. Car will still start and run at this point, just with no dash or gauges. Blinkers and Brake lights worked, so drove it home. At home, started looking at fuses, reading what that that fuse supplies power to. Found a reference to the rear view mirror. Sure enough, the rear view mirror was not coming on. Placed another 10Amp fuse in it, mirror came on for a second, then fuse blew again. Started looking at wiring around mirror and found burned wires. Took off the black cover that hides the wires from the mirror up to the headliner, and found two wires crimped together by the black clips. The guy literally stabbed the loom, and it cut the wires like a knife, but barely made the touch. Anyway, it melted the harnes all the way past the airbag. Split the harness where you can clearly see the burned cable.
Has anyone changed this harness? Looks like a bear. Infiniti quoted 4 hours and 250 for parts. So about 1200 out the door. Have an appointment with them for next Monday. I can get it started, and manually bypass the shift lock and it drives! Should be fun going 65 miles to the dealer that way with no AC...
Part number for the harness is: 24060 3gt4a
