liorkohavi
- Name
- Lior Kohavi
Hi,
I wasn't able to bypass a pollution test with 2013 JX35 model. The results show a high Carbon monoxide (CO) and the engine check lit.
Checking engine code via OBD show an indication for P2097 and P2099 - which represent that the Post Catalyst Fuel Trim System Too Rich (Bank 1 and 2).
Any clue as what should be the real problem and the solution? Note that I realize some old service recall around this issue and wonder if relevant to simple reprogram the ECM or replace sensors etc see 2013 Infiniti JX35: ECM Reprogram for A/F Sensor (Safety Recall)
Best,
Lior.
Best,
Lior.
