- Santa Clarita, CA
- 2005 FX45
Sounds like a solid plan Ed, keep us posted.
How about you join me on this ride! =) You've been quiet on mods for a while![]()
Ed, I'm not ignoring you, sorry. I've been very busy at work. Hopefully I'll have some time to respond to this thread this weekend.
I am trying to plan this out so it is done correctly and in the proper order.
1) Engine Port and Polish of the intake and exhaust ports. Cheapest quote I received is $675 here http://www.eddiesvalvegrinding.com/ Too bad it's in New Jersey. They estimate a 20 hp gain, but I realistically expecting 5-10 hp gain, if that? Maybe with all mods combined and tune, 20 hp maybe real?
2) Next is to install JWT S2 cams with JWT Springs and Shims. Eddie's Valve Grinding quoted at $475 installed vs $1,900 dealership and aftermarket tuning shops.
3) Also, at the same time, have VQ37VHR valve lifters installed. KIERAN -- would you be able to tell what size lifters I would need to get? I'm not sure if your friend has the specs/blue print of the VK45DE S2 Cam, they are custom ground from the VK56DE S2 Cams. This would be great as would save some down time of my car being out of commission as they would have to measure after they install then order the correct lifters.
4) Replace pistons to a different compression?? I am going to stay N/A as I don’t want the headaches of a FI. 10.9:1 is already high, not sure on regular pump gas that you would want to risk going any higher for slight increase in HP.
6) AWD Dyno tune.
Anything else? Port/Polish, JWT S2 Cams, JWT Intake, HKS Exhaust, OEM e-Fan, then Dyno-tune. It would be huge to see close to 300 AWD WHP N/A. With the parasitic loss, I don't think it's possible, but I'm hoping close enough. At least the power change will actual be able to be felt throughout the entire band.
kieran -- very interesting! Thanks for looking into this, great information here.
No problem. I forgot to mention that if you want and you don't have already I can PDF the cam section of the FSM. You'd probably like to have it if you don't already and I'd DEFINITELY share with the shop so they understand what's involved. As you get closer and more serious about it, I can dig into the FSM and read up a bit more on what's involved. I just skimmed so far
Also if you'll be out to the shop, let me know. It's a little over an hour drive from me
FYI-My stock Dyno read W/no mods on a Mustang AWD was 229WHP, (maybe a bit more generous than a Dynapack) 210 WHP seems a bit low as a starting point....
You setting up for this Ed? If you go for it leave a trail of breadcrumbs for myself and my performance shop!
I think I'm pretty much done with mods to the FX, at least for the near future. Saving up for godzilla, lol
You can get a nice Aston Martin for 68,000 prices are cheap now-a-days. Whats better Aston or GT-R aka GODzilla
Upkeep on an Aston probably isn't too cheap, but then again GT-R isn't cheap also.
I'd personally get a 1st year NSX for $20k=) Even I can work on that thing.
The entire video I'm sitting here going would you rev the damned thing already! Oops, description on youtube is deceiving. This video was taken after JWT cams were installed in this Titan
YouTube- 07 Nissan Titan Borla Exhaust
