you could tap a second wire to ACC PWR and add a manual two-way switch. One position would turn on the puddle lights no matter what the dome light is doing and the other position would tie it to dome light operation.
Gonna do it this way also, need some advice.
-----light (red wire) ----->Switch SPDT ONxxxxxxxx /ON switch
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx | xxxxxxxxxxx |
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 12V ACC PWR xxx Domes Light
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx always on xxxxxxx on w/ lights and unlock only
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx |
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx relay fuse box same as OP
here is a diagram i found for motorcycle similar setup different sources of power
12v from battery= ACC PWR ,source of switched power = domes light
Is TERMINAL #1 = red wire for light?
any benefit having relay before or after the switch? If someone could show how to put a single relay instead of 2 seperate relays would be great.
do i need to a relay to the 12v ACC PWR also, or will i only get power when i turn the ignition to acc pwr?
the relay from the OP is running to the domes and white wire going to ?
http://www.r1200gs.info/howto/images/SPDT.gif
