Fire0nic3FX
ITB10012
Don't forget to remind your dealers to use this or mention the TSB to make sure they use this fill pump.
- SERVICE INFORMATION When filling up, checking the ATF level, or if the pan of a RE7R01 series 7 speed automatic transmission has been drained or removed, a special tool must be used. This special tool is the "Transmission Fill Pump", J-49829. For proper use of this tool, go to SERVICE PROCEDURE starting on Page 2. CAUTION: Fill the Transmission Fill Pump with new Nissan Matic S ATF only. Never fill with any other fluid. See this bulletin for further detail.
