J-49829 7 Speed Automatic Transmission Fill Pump
ITB10012
  • SERVICE INFORMATION When filling up, checking the ATF level, or if the pan of a RE7R01 series 7 speed automatic transmission has been drained or removed, a special tool must be used. This special tool is the "Transmission Fill Pump", J-49829. For proper use of this tool, go to SERVICE PROCEDURE starting on Page 2. CAUTION: Fill the Transmission Fill Pump with new Nissan Matic S ATF only. Never fill with any other fluid. See this bulletin for further detail.
Don't forget to remind your dealers to use this or mention the TSB to make sure they use this fill pump.
