Hey guys, any luck resolving this issue?
I had the same problem, my CEL came on with P2135 code, meaning throttle/pedal position sensor switch A/B.
Replaced the faulty pedal sensor part # 18919-AM810 .... now I'm getting new codes P2128 and P2138 which basically the same throttle/pedal position sensor, the only difference is switch E and switch D/E voltage correlation. Car is mostly parked, rarely driven, about 1000 miles/year with mostly low battery symptoms, which might also be causing these electrical glitches.
Any advise what to do? Thnx.
