Is it normal?
Roberts 2006 M45 sport on D2's
Drop was made so both front & rear have the same gap between fender lip & tire.
Thanks Sideways, it was alot of work doing the suspension on the ground with no air tools. It's the 5th suspension I have done on a M.
I think Roberts drop was set at 26.75" from fender lip to the ground
Looks good to me, now I have another question. I'm hearing (mostly when its cold outside) a creaking noise from my front end whenever I go over speed bumps and little dips in the road. What is this?
Freddie, do you have the part numbers for the links?
Or better yet, I'm at 100k and have never done any suspension work on my car since I got it with 32k. What do you recommend I change while installing my BC's?
Sorry I don't have the part #'s as I did it a long time ago. But even so you need to check as my car is a M45, sway bar on the M35 or even M35x may be different.
I would at least change all 4 sway bar links when doing the coilovers.
________________________________________________________________
Please check before ordering:
Front
http://www.infinitipartsusa.com/200...ilizer-Bar-Components-s/17854.htm?searching=Y
Rear:
http://www.infinitipartsusa.com/200...ilizer-Bar-Components-s/17866.htm?searching=Y
Thanks Freddie. I'll confirm and do those as well as they are pretty easy and not too expensive. This is going to be a brand new car when I'm done lol. New suspension, new links, new oxygen sensors, etc. haha.
