Was the whole pod move or just light squeaky noise. If the whole cluster pod move, you just have to tighten down the 4 10 mm bolts. If you remove the knee panel you will see the bolts that holds the cluster pod in place. I can dig up some pics if that the case. If it's some type of squeaky noise, it most likely the front and back pieces didn't not snap in all the way or comes lose, then you just have to line them up and squeeze them to snap together.
