Installing +05 cargo cover in 04 model
tripz
VA
I read someone swapped in an 05-08 model cargo cover in their 04. Does anyone know what side pieces need to be changed for this to work and associated part #s?
Thanks!
Turbocad did this swap in his and needed the two side panels in the cargo area. Not sure if the part numbers were ever posted. He did need to do some minor fabricating to get the clips aligned properly I think.
'apatalk
There is one for 03-04. It has a thin bar. It's just incredibly hard to find. That's why I swapped out my inner panels from an 06 and problem solved. :)
Here is mine, 03-04 Cargo cover
For 2005-2008 conversation you will need #6 Left/Right trims, and brackets/adapters
///8309[/ATTACH]
link
Here it is. Part number H4982-CG025.
$237 at infinitipartsusa
http://www.infinitipartsusa.com/Infiniti-Part-Number-H4982-CG025-p/h4982cg025-.htm
The '05+ just won't fit in the '03-'04 design panels. Black painted cardboard would be a better idea. (and black painted cardboard is a horrible idea but would work, horribly)
The '03-'04 is also a 2 piece item, where as the '05+ went to a 1 piece design. (+ brackets or hardware for each). Don't forget the hatch piece. It all comes complete when bought new.
If '04, check your panels and verify with pictures. The design might have changed mid year.
Here is where it attaches to, see a square cap below the window? That's where 2003-2004 cover bar would slide into.
Cover in place on a 2003
And cargo mount on 2005-2008
GetLuckiFX - So you ordered the two trim panels/the large ones, the female brackets for each side and thats it?
I got an 05 1 piece cover w the metal bar super cheap so Im going to do the swap of the panels too
thanks,
Jim
The only reason I and I know a couple people on here swapped the panels was simply because #1. I like the newer cargo cover better with the thick bar, #2. I got a hell of a deal for both panels and cover from a wrecked FX from a junk yard for $70 each so all cost me nearly as much as a brand new one. But deals like those don't always come along and I'd pay for new panels to fit the cover in, not cost productive. I'd probably do what p&b suggests and sell it and get a 2094 one.
FYI found a link for it too for $215
http://www.nissaninfinitiparts.com/scripts/prodView.asp?idproduct=19721
Thanks for the link and part number :good: major help there bud!!
Anyone found this item (cargo cover) at a cheaper price elsewhere?
cargo cover 03-04
Good luck!! Fortunately mine came in after 6 months of waiting! The boat was traveling extremely slow. Dealer gave me a discount ~$233 plus tax but no shipping charge, just a half yr wait. Nissaninfinitparts looks like they raised the price to $261.
Id definitely order your specific year, took 5 mins to assemble and install w the plugs etc.
Selling my 05 cargo cover now!
