Wow, just did this install this weekend by myself. I definitely earned my man card on this one. I did the rears Saturday and they where not bad at all. All four of those upper shock mount nuts broke free, no problem.
Sunday morning I went back to the shop to complete the fronts and immediately ran into a frozen lower strut mount bolt. After about 30 minutes of toggling between the pneumatic impact wrench and the breaker bar, i gave up and had to come back later due to plans. I coated it in more PB and prayed. Came back, finally broke free. THANK GOD. Both of the lower strut mount bolts on the left side only were pretty rusted up, i think i may replace those bolts sooner than later just to be sure they dont become an issue.
I immediately went around to the other side to ensure that those two bolts were removable from that side before i finished the first side. They both broke free no problem. So i finished the first side. Got around to the other side and found that both of the stabilizer link arms nuts where completely rusted onto the bolt/ball joint. Long story short, and cutting torch and an angle grinder later, the stabilizer bar is free from the sway bar, and i was able to finish up.
Took much longer than expected, mostly because I was scared to do any serious/permanent damage to the FX. As well as the two frozen bolt issues i ran into.
All in all, even though it took the better half of the weekend to finish, I am very glad i did this myself and saved the $650-$1100 in estimates i received.:eek.:
Awesome write up. Thank you.:good:
BTW, those two piece spring compressors from AutoZone are totally fine. Just grease up the threads and use a cordless drill. My Craftsman 19.2V LiIon made the springs no big deal.
