Infiniti OEM Welcome Lighting Ground Kit from Q50 to QX70??
MARUS
Chicago
fx45
Nissan / Infiniti Infiniti OEM Welcome Lighting Ground Illumination Kit - Infiniti Q50 14+ V37 999F4-AX110 999Q9 J2002 - Concept Z Performance
Just came across this factory upgrade infiniti offers for q50 and was wondering if anyone tried this on FX and QX series?? Looks like really nice kit but curious how hard it would be to connect it to FX/QX70 harness?? Shouldn't be that hard i think. They offer some kinda connector too. I have oem illuminating kick plates , so maybe connect straight to them?
What you guys think?
OEM part #
999F4AX110
I received the kit. Plan to install it as soon as warms up. Did some research and looks like this kit is an accessory option and its installed in infiniti and nissan vehicles.
I downloaded installation instructions for q50, q60 and nissan altima and rogue and looks like all of them use the same wires. So I assume will be the same for 2nd gen FX/QX70
All wires we need:
- Room lamp input
- Battery Saver
- Ignition Imput
Can someone help me to locate those wires please? On ‘14 qx70. Are they gonna be on driver side by fuse box or passenger by bcm?
Thanks
I've done this like 4 years ago, I will check my notes of the wiring on the BCM.
This is what it looks like, sorry for the crappy pic.
Ok here are the wires needed to be tapped from the BCM.
Connector M119:
White= Terminal (19) (SB) ROOM LAMP TIMER
Purple= Terminal (4) (P) INT ROOM LAMP PWR SUPPLY (BAT SAVE)
Connector M122:
Green= Terminal (82) (P) IGN RELAY (F/B) CONT
This is for 2011 FX50 FSM BCS-80. Might want to double check the terminal/wire colors but the Signal Name should be the same.
Also the only difference here is that it doesn't fade in and out like the puddle lamps under the side mirror. It's acts more like the map lights except for it being off when car is started and the doors open.
Connector M119:
Connector M122:
Thank you very much. I will look into it
Any update on this? I have this kit on my Q50, would love to add it to my QX70. Any time I ask the dealer they seem to think it cannot be done. Seems a few of you have done this. I am looking at doing it on my 2017 QX70. Any more details on this?
