Infiniti FX 35 HELP!!!
Whiiit
Pismo
FX35 AWD
Whitney
I have an infinit fz34, 2006. I’ve very much enjoyed this car over her lifetime but have always seemed to have something wrong going on. She going on 130,000 miles and has a reaccuring check engine light that haunts me. It will turn over and sometimes have it on the dash and sometimes not, and of course when I plan to take it to the tech for a diagnostic reading it’s off and running fine!
My biggest issue I’m having now is at normal temp., while waiting at a stop light or after just parking she’s looses rpms quickly and then has power loss. In the last age also had the infamous shut down while driving plenty of times. I’ve done the hard battery reset and idle reset, does anyone else have any advice or possibly know what is going on? Could use any help or info or instructions!
Both cam shaft sensors and the crank shaft sensor should be replaced. This should fix your "biggest issue".
Get a tool to scan the computer of your Ixfrinety fz34 to check for current or "pending" codes.
I can agree. Happened to me before I got on the freeway. Can shaft sensors fixed my issue. I had one go bad and as a precaution I changed both.
