I'm getting tired of this !!!
06fx45
usa
john
Hi everyone i need some help with my fx45 to make a long story short it all starts when the service engine light came on then my vehicle feel with no power at all i find out it was the front brake solenoid valve by runing a diagnostic at the auto parts store after doing some research it come out that i had to replace the valve body inside the transmission since you can't find the solenoids it self so after spending little more than 2k in parts and wait almost two months to be shipped from Japan I instaled the new VB in to my tranny add new t-fluid to it the service engine ligth went off but didn't fix the problem 100% now the 45 runs good like before the only thing is when I go from brake to gas to quick the transmission slips a little bit you can actually feel when the gear kicks in it's possible that needs to be reprogram or maybe they sold me a bad part.
Check fluid. Symptoms you have sounds like low fluid. I had to swap vb recently and when I put replacement in, I was short a quart. I had that same lag until I topped it off.
thanks for the help, my fluid was low a little topped off and solve the problem, truck running like a champ now.
