Iforged Classic 2 - 22x10
I am no expert, but from my limited readings it is my understanding that they enhance and compliment the grounding wires and paths already in your vehicle thereby improving performance. Either by smoother idle, smoother transmission operation and the overall feeling that the car is much more connected together. These are just some of the results I felt when I had my grounding kit installed.
Pierce, I just realized that your wheels are staggered... I didn't know that was done on AWD cars... It doesn't "throw" anything off? That must be fun when the time comes to rotate the tires...
He he he....fooled you Ken. No my wheels are not staggered. They are all 10in width all around but the rear(4in) lips are 1/2in wider then the front (3 1/2in)to give it the staggered look. I have not rotated my tires since I had them installed. Can't do it anyways and plus these tires are unidirectional. I also have nismo wheels that are staggered and there are no problems at all with the VDC or ABS.
I don't have pictures and I tried looking for rookies old pictures cause we got the same nismo track wheels but I can't see to find them. However, I will have them on the FX on the 27th at Cal Speedway.
Specs are;
Front: 19x8.5 +25 285/45-19 / 19lbs
Rear: 19x9.5 +30 295/45-19 / 20lbs
These are mounted on yokohama tires. Front and rear are center bore specific to Nissan/Infiniti so no ring adapters are needed.
Here you go sir.
Yeah, I realized that it wasn't in the gallery when I was looking for the pics. Be sure to take some pics when you put them back on.
Yo Doc,
What's the difference in your times when you run with the nismos?
Quick Question; with the tire size from the nismo's, does it throw the speedometer off? i think the tire size is smaller than stock right?
Yo Doc,
Dude, go to the cali speedway event. You're RWD you can run my 18x9.5 Nismos with drag radials!!!
They are indeed shorter than stock. It's the best match up available with decent widths.
Yo Doc,
Definitely quicker with the nismo's compared to my 22in iforged. I can't say for certain how fast cause of too many variables but I would guess about 2-3 tenth.
Yes, as rookie mentioned but its not a huge difference. Plus its only for the track and my speed is already clocked for me on my slip. But on the street the nismo wheels and tire combo feel so responsive and quick compared to my 22's.
2-3 tenths . . feels quicker? No way I'm going any bigger. 35's are hurtin' for power to begin with.
Feels ALOT quicker on the road. But 22's look oh so good. That's the reason for track wheels and 22in. street wheels so one can have the best of both worlds.
