vancityguy
- vancouver
- none
im pretty all over the place with offsets and figuring out what will fit and what wont... for a 2006 fx35 20x8.5-9.5 wheel size what is a good offset. what is the range... will anything from 15-45 fit? guessing the lower the offset(15) the more it will stick out and the higher(45) the more it sits in the fender? right now im running stock 20" sports which are 8" and +40 i believe. wheels im considering are all mostly in the 30-40 offset range... im ordering online so i just want to avoid problems.
also with the centerbore most sites are listing(rims im looking at) in the 73 range but it does list the wheels as fitting the fx35, from my understanding the fx is in 63 range. i am guessing once i order they will send me the appropriate wheel. if not will tire shops be able to put the right ring/adapter or what not on?
im not worried about the wheels sticking out a bit or sitting in a bit at all. i doubt i'd go over +40 and im fine with the way my wheels sit now.
