Hyp flash with front LED turn signalH
Yep Google DIY load resistors and you will find some good hits. Just tap them into your turn signals. One side of the load resistor into each of the turn signal wires (two wires per turn signal) . Be careful about leaving the resistors near other wires as they get really hot.
Here are the parts I used and pics
Sent from my SCH-I510
Tap it in. Make sure the wires you use to tap are long enough so you can properly hide the resistors in the engine bay
