It will fit fine if you go wider, no rubbing or anything if you're at stock height. But I think it's only an 8" wide rim so if you run 275 or 285 tires there will be more tire bulge. It looks a little strange and may lead to slight changes in handling.
If you want to go larger profile, it will likely again fit but your speedo will be off.
Why do you want to get bigger tires on stock wheels?
