how i can advance the timing grade?
you really think worth the invesment to move the ignition timing +2 using a 105 octane,?
based on you experience which can be the best results i can obtain?
by the way bro, i want to upload picture of my instalation i'm be unable to find the way how to attach the local files. i just have the option insert image with URL link.?
A dealer can do it or you can purchase a program called cipher.
http://uprev.com/products/cipher_NI.html
I think the Cobb Access Port for the Z and G can do it as well, I don't think they have FX support though.
Host your picture on Photobucket and then link it using the URL link
Best results will come from a custom tune whether one's bone stock or modded. Timing might be advanced, but will likely retard back to baseline under load. Not a fan of it.
(sequential gas propane system)
That's the propane tank installed to the place where subwoofer is right? I remember your initial post on the .org I guess.. Great improvement for mileage and price per mile but it smells propane (obviously) and can stall sometimes.. If I ever take my FX to Turkey, I'll install one.. At $8-10 a gallon it's not wise to run a 3.5L engine..
if you use a SEQUENTIAL INJECCION SYSTEM OF GAS PROPANE, you''ll not smell anything on the muffler if you calibrate the vehicle perfectly with the computer and the whole map injection. the brand that i use is TARTARINI is a Italian company who really invent the system, and they are established since 1941 in Bologna, Italy.
remember the gas propane is rate a 105 octane.
if you want i can send you picture of it by mail.
everything is manage by ECU, MAP SENSOR, TEMP SENSORS, and can be install up to 450hp engines.
there's no power loss, the gas mileage is almost the same, with one fraction of the cost of gasoline.
more info
www.tartariniauto.it
i want to upload the pictures, but i can do it.
is just for supporter members.
