so I have to went a bit coz I'm kind of clueless of what to do; I'm hoping that the amount of intelligence on this forum will help me to solve this mystery..
it started about 6 months ago... a sound of "unbalanced wheels" whiel I was driving after swapping rear rotor [for performance e-line] changing braking pads and doing some other min0r changes.
I thought that perhaps I have lost the balancing weight on the wheel and got my wheels balanced - it didn't help. the sound of something vibrating [@variable speed depending on the wheel speed kept on continuing].
After a month I have decided to balance my wheels @ a different place. also with the same result.
I have to add that so far:
i have balance my wheels three times [and I have personally checked they are "0"
the wheels are aftermarket verde kaos 20", so I cannot use my nissan guard warranty [dealer said that it will not cover the issue that may relate to drivetrain as these are not stock wheels geez]
I have checked all of the brake pads [evenly wearing]; replaced rear pads [just in case - front were barely used lol]
This occurs while driving at every speed [the vibration accelerates along with fx lol] and slowly the resonance translates onto my interior lol.
I have tried switching to neutral while driving to exclude any issue pertaining to the engine or transmission - it still vibrates the same way ;(
I have also tried to lift each wheel and check if the wheel is loose - [I hope it was a bearing] and nothing.
what can be the cause of this mystery?
aftermarket wheels were not vibrating initially once they were purchased.
front performance rotors are cross-drilled and slotted - I'm ready to replace them, but the issue is not really pertaining to the braking. calipers are clean of marks that would allow me to think that the rotors are scratching them..
I'm in a puzzle. new rotors probably around $250. getting ripped of by infiniti or a local mechanic, may top that amount easily lol
hmmm
thanks for a words of wisdom :P
k.
hmmm
k.
