Horn not working properly
puhahacj
South Bay 310
Have you guys ever had a problem with your horn? Horn works when you use remote lock, but when some a$$hole cut me off really bad yesterday, I tried to honk at him and nothing happened!
The horn doesn't sound when pressed on the steering wheel.....really weird
From S. Bay Infiniti:
"We had to repair a wire at a
multi junction below the BCM in the main harness" Due to water corrosion near the battery area.......
weird.
Horn
My horn quit working. Doesn't even work when I hit the key lock. All fuses work properly. Turns out, its the IPDM and the part is $750. Sounds like the 2004 FX has lots of horn issues and we shouldn't have to spend $1k to alert someone that is coming into our lanes. No recalls yet, but maybe if enough of us complained to Infiniti, they'd do something?:mad.:
Jump the relay in the engine bay horn will work then remove battery under the battery harness going to ipdm there is a blue wire 3 blue wires conecting together it's corroded reattach them horn works
sorry to bring up an old thread but hopefully someone can help.. i haven't tried the fix from FxBroWn yet and i'll do that but i would like to know before pull out the battery. it was a pain in the ass to get in and out.
the 15A fuse is good and the relay is good (i bought a new one and plugged it in)
i jumped the connections and the horn works
the horn doesn't work from the steering wheel or key fob remote
i don't know which pins are which but if you look at the attached pic of the socket where the relay plugs in, i'll call the top one 1, left 2 and right 3.
jumping 1 to 3 makes the horn work and outputs 12.54v
jumping 1 to 2 outputs 11.96v. when horn is pressed, it goes to 12.28v
jumping 2 to 3 outputs .36v. when horn is pressed, it drops to .15v
