hi
hi i have the fx35 2005 . how can i get in diagnosed mode to active the date time running lights? please i need help is gladly appreciated in advance
Welcome to iS!
I'm not sure what you mean with your question but hopefully the reply above helps.
Our US version not wired to have the DTRL on when the car is on. You have to use the above link for the DIY on the Org to mod it up. I have done it, but I ended up taking it off. I can't remember what was the reason for me to take it apart afterward. I'll put it back in tonight to see if I can remember what is it that I didn't like about it.
hello
hi i have the fx35 2005 . how can i get in diagnosed mode to active the day time running lights? please i need help is gladly appreciated in advance
Hey OP, why ask the question again in your own post? Answer to your question is in post #2.
Hi, welcome to the site.
Love my daytime running lights (they come standard on Canadian vehicles)
hello
what happen was i was trying to installed side shine strip led light from the line day time running light . by mistake i hit the cables the fuse got burn i change the fuse for a new one and now the day time running light dont wanna turn on . now there telling me you have to programmed the whole system again i have no idea how to do that . i need help
Who is "they" telling you that it need to be reprogrammed? There are 3 fuses that the DTRL depends on to get power to it. Which fuse have you replaced? There is also a relay in the fusible link. Check the 15A fuse #1 and #22 in the fuse box in the driver foot well. Check the 10A fuse in location #36 in the fusible link block near the battery compartment
