Help with led mirror signals
Renhalt
Lexington, KY
2008 fx35
Ok here's my situation, I have led angel eyes as well as led switchback turn signals with load equalizers. Today I installed led turn signal mirrors, the problem is the drivers side works perfect but when I hook up the passanger side the LEDs won't work and the regular flashers quit. When I disconnect the LEDs and turn the turn signal off then back on they work. I have tried tapping into the rear right with the same results. I know the led mirror signals are working right as I have tested at the mirror as well as the lead running to the fuse box. I have also swapped the left with the right at the fuse box and it works fine. I'm stumped please help! Thanks in advance.
Even though it's small, You're adding additional load to that circuit, so might be worth checking out.
Update! After testing everything over and over. The problem is the f**kin led board, what really pisses me off is one. I bought them from a member! Two, the light works fine when I connect it to my bench top led power source! As soon as I try and hook it up to my car, NO GO!!!!!!!!
As most of you know, painting the covers, tinting the lights, taking the panels off, and taking the mirrors off and apart and then putting it all back together is no easy task!
I sent an pm to the member and we will see how he responds, in the mean time I just ordered another set from guess where? The good ole united states of CHINA!
Interesting, especially since you swapped the left for the right and everything still worked.
