Renhalt
- Lexington, KY
- 2008 fx35
Ok here's my situation, I have led angel eyes as well as led switchback turn signals with load equalizers. Today I installed led turn signal mirrors, the problem is the drivers side works perfect but when I hook up the passanger side the LEDs won't work and the regular flashers quit. When I disconnect the LEDs and turn the turn signal off then back on they work. I have tried tapping into the rear right with the same results. I know the led mirror signals are working right as I have tested at the mirror as well as the lead running to the fuse box. I have also swapped the left with the right at the fuse box and it works fine. I'm stumped please help! Thanks in advance.
