Americanguy
Hey guys I'm new here but thought I'd ask for your advice. I bought a 2005 fx35 sport a month ago with 140000 miles. I changed the passenger side front and rear wheel bearings. While a was doing the front of course the speed sensor broke so I changed that as well. I used auozones duralast part. Everything was good and fine till yesterday 4 different lights popped onto the dash. It's the slip, awd, vdc off, and the abs light. Occasionally over driving the brake light will come on for a second. I have a code scanner and scanned and came up with three codes: c1107 front right sensor: p1722 vehicle speed sensor motor and: p0615 starter relay motor. But no CEL. I filled the brake fluid right up to the max mark. The brake pads and rotors are far from worn out. The c1107 sensors code is for the one I replaced. I took the sensor off and cleaned everything , still the lights are one. With the c1107 is it maybe a defective sensor?? I am annoyed at the lights and wanna clear them if I can. Any suggestions would be very much appreciated!!!!
