Help!!! Water on passenger floor side
Recently returned my car for dealer re-check leak. They worked on sunroof drains. Cost $90.
Now, monitoring if leak shows up again. I'll keep in touch.
After dealer work on sunroof drains. Today rained a lot and have no leaks. Looks this was the problem
I will take some pictures next time I take cowl out.
In the meantime I did put duck tape on the cowl water drainage which is close to a/c air intake. I'm suspecting ton of water going thru that drainage may have some leakage on the wire hardness that goes into the firewall (the cowl drainage is right on top).
Can you please give the part number or photo or the part, because I have the same problem and I cant fix it, and the dealer has no idea which is this part. Thanks
Having the same problem and just keeps getting worse UGH. Need to go searching for this f'n part my passenger side floor, inside of the windshield, and nowww my driver side floor are SOAKED and my car smells like horrid mildew. I have a 2016 QX70S sports package with all the dark trim on the outside, black leather with purple stitching the inside...only 38,000 miles...and was the most expensive purchase of my life besides my house and the f'r that changed my battery out has RUINED my SUV. UGHHHH
Years later: anyone have the part number?! Thank you.
